Any suggestions on creating a inclined barrel vault
Does anyone have any suggestions on taking a barrel vault and sloping it front to back (Inclined Barrel Vault?)?
Thank you.
7 REPLIES 7
Here is a jpeg to illus. Would like to slope the barrel over the Entry.
Thanks
Djordje
ArchiForma.Off the top of my head, there are at least three ways to model it. Then you can use SEOs.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thank you.
Try making the barrell vault then saving as a library object then SEO to trim the faces vertical - very tedious I am afraid.
had also wanted to find out how to make an inclined hedge element.any ideas out there!
And Djordje,what are SEO's
Thank you all for you suggetions and dido Andrew's questions "What are SEO's?"
Thanks again for the quick responses
Petros Ioannou
Solid Element Operations (Edit menu)
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Djordje
http://www.graphisoft.com/community/archicad-talk/viewtopic.php?t=1674
Djordje
HP Omen
