Any way of exporting Project Preferences?
I looked around for big 'Export' buttons but I can't find any.
7 REPLIES 7
No way at all. Can´t you use a template file? It comes with all the Project Preferences. You can also open the template and merge another file in it, if it's already started..
That sort of sucks doesn't it.
If you realize this early in starting a new project, maybe you can
1. Open the project you want to use the Project Settings of
2. Start a New Project and select to use latest Project Settings
3. Open your new file and copy everything to the Clipboard with the Thick Marquee
4. Paste them to that new Project.
Thanks Stein and Laszlo. Once you are deep into a project any approach is probably more cumbersome than just going in and making the changes manually. As with any piece of user-defined project-based set of data, I think it should be exportable etc. and I can't think of a reason why it is not. Everything should be exportable. Graphisoft come on, stop the consistent inconsistency.
Link
Hey! You're starting to sound like a beta tester!
Link.
Djordje
Deserves to be one, definitely!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Link
Absolutely! And with an attitude like that he'll go far!
Interested, Ignacio?
Link.
