2024-03-07 05:00 PM
Has anybody noticed this also and found a way to make this behaviour go away?
I select any element (either on plan or 3D view) and if I don't wait for 1-2 seconds after selecting the item, the element will always think I want to move it. Therefore, if I am trying to work quickly and just select the item and then move the mouse over the the Info Box to edit any settings, the settings will be grayed out because the element is in the middle of a move command !
I've been using Archicad since version 10 and this has now been happening on version 26 and 27, but only if I use any of my Apple M1-equipped Macs. I use a MacBook Pro and a Mac Studio, both of them with the Apple M1 Max chip and they both behave the same.
Does anyone think of any possible setting in the Work Environment that could help with eliminating this behaviour? It gets kind of tiring trying to quickly select items, but having to wait a couple seconds after selecting a wall, a slab, an object, etc., because if I don't wait then it'll think I want to move the objects.
Solved! Go to Solution.
2 weeks ago
Here is the reply from the developers which I've received yesterday night:
Thank you for reaching out. We are aware of this issue. Magnet performance improvements from the last update are in conflict with Archicad non-standard window handling. We are doing our best to submit a fix to the App Store as soon as possible.
Hopefully this fix will arrive soon.:)
2 weeks ago
The same here! Thanks, saved me from a lot of anger!
2 weeks ago
Thank for the tip! It works if in settings you deactivate the option Mouse: Snap windows by dragging. The problem magically disappeared 🙂
a week ago
i can confirm that magnet was the problem for me to.
i used magnet for years.
i guess is a bug caused by the latest os updates.
i had the same problem in AC 27 and AC 28
Sunday
Works like a charm now. I MO Archicad shouldn't have conflict with Magnet. Developers should check it.
Managing windows in Sonoma is way from perfect on Mac.
Best
Karol
