Arched opening
In an arched/elliptical opening, how does one make the masonry/material of the actual arch different from the the wall in which the opening is placed.
Any help would be appreciated. If this has already been discussed before, if you can point me to the right thread.
Thanks.
David Maudlin
sinnerman:
Welcome to the forum. You are more likely to get help with this problem if you tell us the version of ArchiCAD you are using and the specific name of the library part.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Can you use the "header arch" object and make that a different material?
I used that to make a soldier course above a masonry porte cochere, don't see why you cant change the perimeters to get what you want.
