ā2006-01-01 03:58 PM
ā2006-01-01 04:01 PM
zucoc wrote:Just like all the ArchiCADs until now ... whatever you are able to do with it, otherwise nothing on its own.
GS please give us a list of ac 10 will be able to do
ā2006-02-01 09:23 PM
ā2006-02-01 09:45 PM
ā2006-02-01 09:47 PM
ā2006-02-01 09:52 PM
Informations I'm about to write are not confirmed. I found them on polish archicad forum and they're just some first impresions from beta version of AC 10. Like below:
- Plotmaker will be finally soak into ArchiCAD, you'll be able to use it via project navigator, also you can assign different pen sets to different layouts
- coordinates and control bars will be convert to a kind of pet palette which follow cursor, so you'll have it always at hand
- there will be "mesuring tape" tool for easy mesure of distance between any two points
- menu options were reorganized, for example "display options" has its own preview window so you can see how your configuration will affect the plan
- you can finally do sloped walls and posts without gdl script, also bottom and top thickness of a wall can be different
- fills can use gradients now (linear or radial)
- fills have their own X Y axis and can be resized independently (you can change proportion of a pattern) and what is more - bend them
- "see what you're about to select" function, cursor recognize what is under it in 2D and 3D
- one navigation orbit in 3D!! shift+mouse for navigation instead of previous 3D navigation palette
- Lightworks environment seems not to have any major improvements
The same lousy material preview window, no radiosity.
Looks like they focused on some long-time-needed improvements more than on making revolutionary release.
_________________
Pawel Kruk
ā2006-02-01 10:45 PM
ā2006-02-01 11:15 PM
ā2006-02-01 11:46 PM
Rakela wrote:Just HOPE that is not all, just hope....Informations I'm about to write are not confirmed. I found them on polish archicad forum and they're just some first impresions from beta version of AC 10. Like below:
_________________
Pawel Kruk
ā2006-02-01 11:54 PM
