ArchiCAD 11 Hotfix-1210
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
We have found a serious bug in the Interactive Schedule Add-On that may cause incorrect values in zone schedules. To fix this, we have released today Hotfix-1210, which replaces the Interactive Schedule Add-On.
Hotfix-1210 is unusual in the way that it is not a cumulative patch, so it can be applied only to a build 1200 ArchiCAD. If you are on an older build, you have to install build 1200 first.
The Hotfix is available through 'Help/ Check for updates' or through the automatic update. Please do read the Release Notes, if you are upgrading from 1114 or earlier.
Gergely Kmethy
45 REPLIES 45
Eduardo Rolon
Restart didn't help.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Does 'Interactive Schedule.apx' exist at all in the \ArchiCAD 11\Add-Ons\Standard folder?
Gergely Kmethy
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
SteveC0013 wrote:
I've been to the update page. 1200 is not available to me there.
When you go to 'Check for updates...', you should see something like this. Is this not what you get? Can you please post a screenshot?
Gergely Kmethy
Eduardo Rolon
Yes.
AC28 US/INT -> AC08
another Moderator
I am having the same problems & message?
What next?
Joseph
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Please check that you have Read&Write permission to ArchiCAD folder, and all files and subfolders in it. The installer gives this message if it has insufficient rights.
Gergely Kmethy
Fra
I also having the same problem ......
First I update my ArchiCAD v1114 to 1200 with nothing problem
When i update to 1210 i have the same messagge
I check the permission folder ...
Francesco
MacPro, Ram 4 gig
OS X Leopard 10.5.2
AC 11 Ver 1200 ita
AC25 AC26 (Ita)
Mac Studio M1 Max 64 GB - OSX 12.4
Yes,...
I have Up to date
AC1210 hotfix only installed Add-Ons\Standard\Interactive Schedule.apx
Thanks GS
Eduardo Rolon
Changed all permissions, does not work.
AC28 US/INT -> AC08
another Moderator
I used DiskWarrior & Fix Permission of OS X and it finally worked
