2008-04-11 01:06 PM
2008-04-13 10:55 PM
2008-04-14 06:36 PM
Thomas wrote:Thomas I do not know what ACL is but this is the process I go through when installing any major or not so major Software/FirmWare installation, which for the 1st time did not do it for Built 1210 and got me:
.........ACL permissions ...................?
2008-04-15 12:09 AM
another Moderator
2008-04-15 02:49 PM
Joseph wrote:Thanks Joseph. Access Control Lists is the new kind of 'extra' permissions that Apple has introduced in Leopard. (I think it's a BSD/Unix thing, not their own invention).
2008-04-15 03:04 PM
another Moderator
2008-04-15 03:21 PM
Thomas wrote:I still think you took the right approach. I've never done a clean wipe and re-install when upgrading, including the move to Leopard, and suffered no ill-effects. A complete reinstallation would be a disastrous waste of time. Before upgrading I always:
I regularly read Macfixit, but it seems to me they've gone a little too far in crying wolf the last couple of years. But this time I should have listened and done a clean wipe and install. I just thought it was too much work.
2008-04-16 07:43 AM
2008-04-16 09:59 AM
Ralph wrote:I did that. I always do. This time, it wasn't enough. As you know, I got the nasty unknown group weird permissions issue, whcih Ejrolon helped me solve here:
- - Run Disk Utility to repair permissions and verify
- Make a comprehensive backup
I'm also quite selective about I install. Some Mac users have fallen foul of 3rd party applications which used undocumented APIs and caused no end of problems under Leopard.Absolutely. But I have not, unless you count EFI Fiery systems as one of those. Problem is we need it.
2008-04-16 10:04 AM
Ed wrote:Ed, I think you're right. But please tell me if there is a way to completely turn ACLs off, or at least allow full ACL access to every file and folder at this moment, so that only the 'ordinary' permissions apply?
A subtle tip from Graphisoft Technical Support.
Avoid ACL for the time being on the Mac. Unless you like surprises -- that is.
2008-04-16 02:20 PM
