Greg Kmethy
ArchiCAD 11 Hotfix-1210
We have found a serious bug in the Interactive Schedule Add-On that may cause incorrect values in zone schedules. To fix this, we have released today Hotfix-1210, which replaces the Interactive Schedule Add-On.
Hotfix-1210 is unusual in the way that it is not a cumulative patch, so it can be applied only to a build 1200 ArchiCAD. If you are on an older build, you have to install build 1200 first.
The Hotfix is available through 'Help/ Check for updates' or through the automatic update. Please do read the Release Notes, if you are upgrading from 1114 or earlier.
Gergely Kmethy
VP, Customer Success, Graphisoft
45 Replies 45
Thomas Holm
Additional info on Leopard permissions here.
aahatimo
thanks thomas!
still on 10.4.11 here, for a little while longer. not really wanting to reinstall ac11. use cocktail to repair permissions weekly.
1200 has been working for me but, i have been having library problems when sharing files w/ someone on 1210 & leopard.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
aahatimo
worked fine after a fresh upgrade on new mbp.
tim hanagan
I looked for this answer elsewhere but didnt find it. I have AC11 build 970. I am ready to update everything but since 1210 isnt cumulative I am wondering if the other hotfixes are. Can i just install 1200 and then 1210 and be done or do I need to install every hotfix from 970 to 1210. Any help would be greatly appreciated.
Thanks again,
Jason
gorilla_monsoon wrote:
Thanks again,
Jason
1200 is cumulative so it should install over 970 just fine. This is typical, 1210 is an exception.
Mr. Lohden,
Yes I installed 1200 and then 1210 and everything works fine. Thanks for the help.
