ArchiCAD 15 Hotfix-3
AndorSzoke
In the last couple of weeks we have found and fixed a few dimension loss problems in ArchiCAD 15. ArchiCAD 15 Hotfix-3 package (build 3632) for BIM Server and ArchiCAD15 has been released today as a solution to these problems.
A large number of localized hotfix versions are available through the automatic update system from today. Further versions are under testing.
Please take a moment to read the Release Notes, and the list of fixed bugs:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC15-3602to3632-ReleaseNotes.html
Another ArchiCAD 15 hotfix solving general problems will be released in the near future.
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
6 REPLIES 6
Djordje
The hotfix is installing literally since the morning, and is not finished yet ... does anybody else have the same issue?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dennis Lee
Ours installed fine. Bim server and clients. Windows 7 x64 professional, 4 machines.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
2 minute install for me, no problem.
It installs just fine for me and have done so on a few machines now (all Windows machines).
But on one machine in particular it does something to the WIBUkey software and Archicad will no longer run - WIBUkey error.
It is fine straight after the install and works perfectly but won't run after the machine is restarted.
It also stops any other version from running.
I uninstalled 15 and the other versions worked again.
Re-installed 15 with no hotfix and all was fine (even after restart).
Installed hotfix 3 again and all was good until the machine was restarted.
So un-installed and re-installed 15 again and upgraded to hotfix 2 and all is fine again.
I won't bother with hotfix 3 on this machine.
At least I now know what it is if other users suddenly start not working.
Waiting for hotfix 4.
Hi
Anyone having an issue with JAVA? I've only tried installing it on our BIM server so far, but it says that Java needs updating even though I've done that. Which version of Java is required? the update says to "put in the HOTFIX 3 CD" which of course I don't have since everyone downloads hotfixes...
ok, never mind. I've resolved it - I tried to install a java update that wasn't compatible with our server OS
