ā2013-02-07 04:16 PM
ā2013-03-14 01:20 AM
ā2013-03-14 02:31 AM
ā2013-03-14 01:42 PM
Matthew wrote:Don't see it here.
...Has anyone else seen this?
ā2013-03-14 09:53 PM
ā2013-03-15 01:07 AM
ā2013-03-15 11:03 AM
Has anyone else seen this?[/quote wrote:
Yes, I get this too. I have changed my Nvidia drivers, but the problem persists.
ā2013-03-19 02:55 PM
solitaire wrote:We are sorry to hear that the graphics card update did not help. Does this affect all of your projects or does it appear to be specific to one or more projects? Try with an empty file and let us know the result. This test may help us to get closer to the source of the issue.
ā2013-03-20 01:59 AM
Marton wrote:I only have one project. I will try this on an empty file and revert.solitaire wrote:We are sorry to hear that the graphics card update did not help. Does this affect all of your projects or does it appear to be specific to one or more projects? Try with an empty file and let us know the result. This test may help us to get closer to the source of the issue.
ā2013-03-20 07:51 AM
ā2013-03-20 08:48 AM
solitaire wrote:The 3D is not re-calculated every time, I guess the full rebuild is slow in this case. Do you have many complex profiles, solid element operations? Before installing this latest hotfix was it significantly faster?
On a separate note, is there a tool for cleaning up plan files? Since hotfix 3, my project takes about 5 mins to convert to 3d even when I select a small part of it in the marquee. This is a sporadic problem; sometimes it is quick (less than 10 secs) but for a majority of the time it is excruciatingly slow. I have tried it on my laptop and my desktop and the issue is the same on both. Which is why I am thinking perhaps the problem lies with my project file.
Thanks.
