ArchiCAD 16 announced
62 REPLIES 62
Weird. I'm registered for the USA.
But, yes, there IS a difference between INT and USA. Primarily the story numbers - USA story 1 is INT 0, the default template/attributes, and of course you'd get the INT library and not the USA library.
TDabney wrote:
I have rec'd my disk in the mail, but unfortunately my new MacBook Pro w/retina display doesn't have a disk drive!
Hi Tom,
Hope your summer's going well - good but hot/dry here.
The best bet is to create a disk image of the DVD on another Mac if one is handy and copy it to a thumb or other external drive (or over a network).
If you're not sure how, here's one set of steps I found Googling to save me from typing 😉
http://mactips.info/2012/06/make-disk-images-from-installation-cds-before-its-too-late
Eduardo Rolon
If i remember correctly.
Under Utilities in the Application Folder you can also find the Disk sharing utility that lets your Mac connect to another Mac's DVD drive.
Warning it might be slow though I have not tried it yet.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
