2013-09-17 10:02 AM
2013-09-22 01:27 AM
2013-09-22 03:45 AM
another Moderator
2013-09-23 07:21 PM
2013-09-24 02:20 AM
ejrolon wrote:Thank you Eduardo you were right-
Could be a permission problem. To change the permissions in the folder. Select it -> press command+I, look for the permissions tab, change items to read and write, select gear and choose Apply to Enclosed Items.
2013-09-24 08:53 AM
Rick wrote:Rick, I wonder if the download is incomplete. If you right-click the Hotfix installer and choose "Properties" the size should be reported as: 222MB (233,384,784 bytes). Try downloading the hotfix again. Sometimes using a different browser can help. Also it is recommended that if you have any anti-virus software that you disable it for a few minutes while installing the hotfix to avoid the install process being falsely interrupted.
I have an error message when installing the build 4005.
" win64.exe is not a valid Win32 application"
help please.
2013-09-24 05:29 PM
2013-10-01 03:45 PM
Robby wrote:ejrolon wrote:Thank you Eduardo you were right-
2013-10-02 11:11 AM
