fuzzytnth3
ArchiCAD 17 am I missing something?
In previous versions of Archicad if an element that spanned across a number of storeys was allocated the wrong storey and you wanted to correct which storey was it's home storey. You could select the preferred storey in it's settings and it would have no impact on how it was positioned in the model but now in AC17 it jumps a storey.
In Archicad 17
https://dl.dropboxusercontent.com/u/399074/sites/trapdoor/AC17homestorey.m4v
In ArchiCAD 16
https://dl.dropboxusercontent.com/u/399074/sites/trapdoor/AC16homestorey.m4v
Is there some way of getting the old AC16 behaviour so you don't have to edit its base and top heights to keep it in the correct relationship?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
2 Replies 2
Eduardo Rolon
Read http://archicad-talk.graphisoft.com/viewtopic.php?t=42871
To sum up, it is a feature, most users don't like it and they are fixing it in the next Hotfix.
The trick in the meantime is to use the "Relink to Home Story" to change the story of the object, right click after selecting object.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
fuzzytnth3
Ah missed the earlier post. Thanks for the solution using the context menu
