2013-05-07 05:18 PM
2013-05-13 09:07 PM
Karl wrote:Also beware when you are making new composites. There is nothing to indicate which side of your composite the reference line will be on. The reference line of the composite will be at the top of the window where you assemble the materials. Knowing this may save you the trouble of having to reassemble your composites to be consistent with what has been arbitrarily designated as inside or outside in some other place.
OT since two people have asked why we have reference lines: Reference lines are critical; do take the time to understand how they are used and can be used.
The reference line for a wall, for example, "anchors" a space-critical surface of the wall (your choice of what you deem space critical). Frequently, the reference line might be the exterior structural face of a composite or profiled wall. By placing the wall with the reference line there, you can change the entire assembly of the wall and still have the structural, bearing volume of the new structure aligned at that position, all in one step by selecting a new wall type. The exterior skins may grow or shrink. The core(s) may grow or shrink, and the interior finish skins can grow or shrink, but the entire structure will align as intended - e.g., outside face of bearing core to outside face of bearing core below / outside edge of slab below, etc.
2013-05-14 09:15 AM
dasneboja wrote:This new morph capabilities seems nice, but I am not sure if you can use it to model a building out of it as in Revit, where you can directly apply walls, curtain walls, slabs etc to mass you model with that tool.
Am I the only one appreciate new morph mass modeling capability??
This is something that Revit has long time ago...
I was constantly finding better way to start project in ArchiCAD
and finally we have a tool for it!
2013-05-14 02:47 PM
Thomas wrote:This clip can be a bit misleading because of the reason you mentioned. So I have indicated this to the guys at Graphisoft.
In the demo video
Archicad 17 New Features: 014 - Model-based element display and solid element operations
http://www.youtube.com/embed/KbvnDzzoaqM?hd=1&autoplay=1
the narrator says "the correct 3D contours of model-based elements are displayed on the floor plan" (my emphasis)
and
"not only 3D elements, but also Solid Element Operations, are displayed correctly on the floor plan"
I can't find any statement limiting this to Morphs only (as in AC16) or such.
Seems to me this is what we've been asking for. Even if I have to use the "horizontal 3D document" method, as long as it's the one-click method described, anddoesn't limit me in any other way, it should work and eliminate the need for Bricklyne's workaround.
Please correct me if I'm wrong!
2013-05-14 02:55 PM
Steve wrote:Steve, are you talking about ArchiCAD 17 here? Or previous versions.Karl wrote:Also beware when you are making new composites. There is nothing to indicate which side of your composite the reference line will be on. The reference line of the composite will be at the top of the window where you assemble the materials. Knowing this may save you the trouble of having to reassemble your composites to be consistent with what has been arbitrarily designated as inside or outside in some other place.
2013-05-14 04:31 PM
laszlonagy wrote:Thomas wrote:This clip can be a bit misleading because of the reason you mentioned. So I have indicated this to the guys at Graphisoft.
In the demo video
and
So the situation is:
Results of SEOs do not show in Floor Plan Viewpoint for most elements. The only elements it does show is Roofs, Shells and Morhps.
However, it is now possible to create 3D Documents based on the Floor Plan. So you don't need to go to the 3D Window, create a Top View and generate a 3D Document from that; you can do it from the Floor Plan. In this case, since the 3D Document is generated from 3D, the SEOs WILL show.
So indeed, Thomas, this could be a solution to many situations.
The only qualifier is that since it is a 3D Document, its settings will govern the display. So some options that you have in Floor Plan, you will not have in this case. For example, Floor Plan Display Options for elements, like Projected with Overhead, will not be available in this case.
2013-05-14 04:39 PM
Thomas wrote:They are working on it.
Thanks, Laszlo, for the clarification.
I really think that the naming and narration in that video should be corrected too.
2013-05-14 04:52 PM
Bricklyne wrote:
...I can't tell you how many times (even in the last few weeks) I've had to resort to the old work-around of saving a .jpg image file of the top view in Axonometric on the 3D window and then saving that image as a worksheet and then scaling it to the right size by referencing the floor plan through virtual reference and then finally using virtual reference again on the floor plan with that image to trace the correct SEO cut of a cut element just to have it display correctly on plan.
2013-05-14 05:28 PM
laszlonagy wrote:Fine! Thanks!
2013-05-15 01:16 AM
2013-05-15 05:05 AM
Thomas wrote:Thanks for the tip.
Bricklyne,
as I seem to be finally joining the "grumpy old men" section of this forum, (see my other post), I'd like to balance it on the positive side by pointing out (for the public) a somewhat easier solution to your problem, that is the workaround ofoverlayinga saved 3D document view/horizontal 3D cut/ with the regular floor plan on a layout.
Of course it doesn't solve every presentation problem, and I guess you're already familiar with it, but I don't think every novice that reads this forum knows.
With the right settings, this way gets you an invisible and auto-updated layout patch with correct cuts and no need for repeated manual interference like the technique you describe. Still a workaround though.
Edited: This overlay-views-on-layout technique could of course also be used to solve the issue that eduardo rolón names. (together with setting 3D door opening angle to the same as in 2D)
Best regards, Thomas
