ArchiCAD 18 Update 4006 available
The first update (hotfix) to ArchiCAD 18 is now available at:
[deleted]
List of improvements in this update is at:
[deleted]
Edit: sorry, that was a false alarm based on incorrect information from a source other than Graphisoft.
24 Replies 24
__archiben
Be aware: all of my complex profiles that had been mirrored have re-mirrored themselves back to 'normal' upon upgrading to 4006... which is more than slightly annoying to say the least....
~/b
b e n _ f r o s t
Eduardo Rolon
…and the US version lists "no update available" at this time.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
__archiben
yeah - same here: "Check for updates..." within ArchiCAD reports no updates available but it's there if you follow Laszlo's link...
~/b
b e n _ f r o s t
...and the Mac version downloaded from Laszlo's link (because the Update process does not present the file)... is NOT signed by Graphisoft and so cannot be installed on Mavericks without disabling security settings.
Mac version should be recompiled by GS with proper code signature.
Greg Kmethy
Laszlo jumped the gun. The first Update for ArchiCAD 18 has not been released yet, due to the code-signing error that Karl points out. This problem was introduced with the latest Mac OSX updates, and we realised this just before we were to release the Hotfix. We are recompiling the packages and will announce when the Hotfix is ready to go.
The best way to download a Hotfix is through the "Check for updates" command in ArchiCAD.
Gergely Kmethy
VP, Customer Success, Graphisoft
Eduardo Rolon
and what about us that jumped the gun and installed it?
AC29 US/INT -> AC08
TMA_80
Will there also time to check this :
http://www.maxwellrender.com/forum/viewtopic.php?f=109&t=42663
AC12_27 |Win11_64bit|
Marton Kiss
The identified problem only affects the installation, so if you have already installed it, there should be no troubles.
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Aaron Bourgoin
hahaha!
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
