2014-05-06 03:44 PM
2014-05-16 01:00 PM
Ivan wrote:The carpet is not an object it is a C4D Material (Procedural with Displacement) optimized for use in Archicad so it will not export to Artlantis.
Can we export this grass and carpet as real 3d objects into Artlantis, or it works only in Cinerender.
another Moderator
2014-05-16 05:19 PM
ejrolon wrote:So if the "minimum" reserved cores is 3, wouldn't that mean the maximum number of cores ever available for rendering with my 4 core iMac is 1? Or did you mean something else?
If I understood correctly at a minimum AC will leave 1 core for the OS, will use 1 for itself so you can keep working, another for PBC-section/elev generation and the rest for rendering.
2014-05-16 05:25 PM
another Moderator
2014-05-16 05:29 PM
Karl wrote:Well, if it is really "tuned for CineRender" that would deserve applause!
A standard material library, tuned for CineRender, comes with AC 18.
2014-05-16 06:47 PM
MSotero wrote:Just grass-like things. You can change parameters for the blade length/height, width and density.
The grass thing sounds cool. Does it only do common grass or can it be manipulated to look like similar forms of ground cover?
2014-05-16 07:00 PM
costingh wrote:Management of cores is an operating system function, along with the number of threads the app creates, priority-setting by the app, etc. Either 3dsmax has given itself highest priority and/or your computer only has one core (100% = 1 core), and is underpowered to run multithreaded apps.Karl wrote:Hmm, after I hit the render button in 3dsmax, the CPU usage jumps to 100% and i can't do anything on my computer, not even web browsing. This means that Vray is squeezing every last drop of CPU power for rendering, and that's what i'm expecting from an rendering engine. It seems that's not the case with the new rendering engine? Or it has a "background rendering" mode which it's not using all the CPU cores, besides the normal rendering mode?
Renders happen in the background, so you can keep working in AC as they happen.
2014-05-16 07:58 PM
2014-05-16 08:13 PM
2014-05-16 10:06 PM
costingh wrote:I'm surprised that in this day and age people still don't know about setting core affinities for various programs and tasks in Task manager in Windows.Karl wrote:Hmm, after I hit the render button in 3dsmax, the CPU usage jumps to 100% and i can't do anything on my computer, not even web browsing. This means that Vray is squeezing every last drop of CPU power for rendering, and that's what i'm expecting from an rendering engine. It seems that's not the case with the new rendering engine? Or it has a "background rendering" mode which it's not using all the CPU cores, besides the normal rendering mode?
2014-05-16 11:59 PM
