2004-03-24 03:25 PM
2004-04-07 03:50 PM
another Moderator
2004-04-07 06:22 PM
Rick wrote:This was my first surprise-!! Selecting save from the file menu has caused a few crashes, wether or not anything was selected on the floor plan, it has not happened with the key commands.
2 things
Anyone else crashing if they save with something selected? This might not always happen, but several times as I save... example - just in case the section I am deleting is the wrong one, AC crashes (build 2256)... big help to save.
I moved preference to a new computer, and now I am warned that add-ons are missing. It is the "check doubles" add-on, and it is actually there, but also listed as "not found" (so twice), and it want let me remove it. Any suggestions, maybe which preference stores those?
thanks
2004-04-07 06:22 PM
2004-04-07 07:11 PM
2004-04-07 10:45 PM
2004-04-12 08:29 PM
2004-04-14 12:00 AM
2004-04-14 12:09 AM
2004-04-14 06:14 AM
A shared library is a code fragment used by the application and has nothing to do with the object libraries or the network.Thanks Matthew,
A fresh install would probably fix things up.
2004-04-14 04:48 PM
another Moderator
