There is a new (as of yesterday) bug fixing patch @
http://tr.graphisoftus.com/
Here are the release notes;
TeamWork Hot-Fix for 8.1 R2/v2
This hot-fix patch has been released to address the most significant problems emerged with 8.1 R2/v2. We also continue to work on fixing other problems and we are going to release an R2+ version at a later time. The current hot-fix can be used for updating all the existing 8.1 versions (R1, R1 Patch, R2) {}. It means this patch contains all bug-fixes released after 8.1 R1/v1. ArchiCAD 8 users first have to upgrade to ArchiCAD 8.1 before they can use this patch for having the most current version of ArchiCAD.
The following major inconsistencies are addressed in this hot-fix:
- Can't access network library through library manager in Mac OSX.3.2
- Can't access local library through library manager on Mac OS 10.3
- Fonts replaced in Teamwork when different font-sets are used
- Missing label text in TeamWork
- Custom R1 keyboard Shortcuts cannot be imported into R2
- Crash after receive changes in teamwork
- Copy paste error with locked 2D element
- Insert Above/Below Story in Navigator can cause wrong elevations
Compatibility note:
This hot-fix does not update IFC add-ons. The R1/v1 version of the IFC add-on is incompatible with later versions of ArchiCAD. If you utilize IFC we highly recommend downloading the IFC 2x2 Add-On for AC 8.1 R2/v2 to avoid serious problems. The IFC 2x2 add-on is available on our website [
http://www.graphisoft.com/products/ifc/beta_download/] for download.
Macintosh:
Download the appropriate patch file for your localized language version of ArchiCAD.
Unstuff the file's contents to a folder.
Run the updater application.
Locate the installed ArchiCAD's folder with the installer if necessary.
The system might require you to give an administrator password in order to be able to modify ArchiCAD (the application itself).
Windows:
Download the appropriate updater archive and unzip it.
Run the updater.
Locate the installed ArchiCAD's folder if necessary. (You need to be able to modify the installed ArchiCAD application which might necessitate to run the updater with administrator rights).
Note that the application ArchiCAD must not be running when running the updater.
After successfully finishing the update process, the application ArchiCAD should display (2275) in the Help menu / 'About ArchiCAD®...' window in the lower right corner.
Notes for Door & WindowBuilder Users:
If you are a registered user of the D/W Builder please go to this page:
www.theometric.co.nz
