ArchiCAD 9 Hotfix Build 2172
Chazz
http://tr.graphisoftus.com/ wrote:
ArchiCAD 9 Hotfix (Build 2172) can be found within the ArchiCAD 9 application menus. Go to the [Help menu >> Check for Updates...]. When appropriately installed, ArchiCAD 9 [Help >> About ArchiCAD] will show as Build 2172. You may also use the mirrored links: ArchiCAD 9 Hotfix (Build 2045) Mac {48.5 MB} / Win {31.3 MB} This version is for non-EDU users only.
Anyone tried it?
And why would the mirrored link be for 2045?
Nattering nabob of negativism
20 REPLIES 20
Just installed the 2172 update.
When I opened Archicad for the first time the option to sign in to a group project was greyed out.
Also, 1) the Teamwork menu has disappeared!
2) The splash screen in "Help -> About" doesn't mention "Archicad 9 for Teamwork" just 2172 INT Full.
Any ideas??
