2005-02-02 06:06 PM
2005-02-02 08:12 PM
2005-02-03 02:09 AM
2005-02-03 08:35 AM
2005-02-03 10:39 AM
F. wrote:You could try rebuilding permissions or deleting prefs but you probably have done that already.
After Installing the Patch, AC does not start anymore.
Any hints?
AC9v2 (of course), MacOS X 10.3.7, G4, Ram-Mhz-HD enough.
2005-02-03 11:20 AM
You could try rebuilding permissions or deleting prefsThis was the hint of the german support. This has no success.
2005-02-03 06:54 PM
2005-02-03 07:07 PM
2005-02-03 07:39 PM
gkmethy wrote:I have multiplied the whole ArchiCAD folder, and changed the name of Archicad executable to Archicad2, then what happens? Is it going to update Archicad2 executable when I point the finder to Graphisoft2/ArchiCAD 9/ folders.
If you have multiplied the whole ArchiCAD folder, then you can patch them one by one pointing installer to the respective folder.
Greg
2005-02-04 12:54 AM
Joseph wrote:no. it looks only for an app called "ArchiCAD". you should know that you no longer need to duplicate the entire archiCAD folder in order to run several sessions of archiCAD - just the application file itself.
