ArchiCAD 9 Subset Library SLOW
We have a project in ArchiCAD 10 Teamwork, and on one of our workstations, when it starts loading the ArchiCAD 9 Subset Library, it slows to a crawl. I've watched the CPU meter and the CPU usage never goes above 3%! It takes about 6 minutes to get to the point where you can finally sign in to the project. We don't have this problem on any other station. It's a brand-new station, and reloading AC10 didn't help. Any ideas?
The subset library and any other standard libraries are installed locally on each workstation, right? (Not loading over the network.) If so, then I don't have any idea what could be causing the problem...
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
We have tried both configurations -- loading through the network, and load from the local disk. Both yield the same problem.
