ArchiCAD 9 Subset Library SLOW
We have a project in ArchiCAD 10 Teamwork, and on one of our workstations, when it starts loading the ArchiCAD 9 Subset Library, it slows to a crawl. I've watched the CPU meter and the CPU usage never goes above 3%! It takes about 6 minutes to get to the point where you can finally sign in to the project. We don't have this problem on any other station. It's a brand-new station, and reloading AC10 didn't help. Any ideas?
2 Replies 2
The subset library and any other standard libraries are installed locally on each workstation, right? (Not loading over the network.) If so, then I don't have any idea what could be causing the problem...
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
We have tried both configurations -- loading through the network, and load from the local disk. Both yield the same problem.
