2007-01-22 08:52 PM
2007-05-02 05:48 PM
refs wrote:I think you're missing the difference between "I can't" and "Archicad can't."Bricklyne wrote:This issue is dedicate to you.
... for Revit users, who claim to know AC, but who really have clearly lacking or insufficient knowledge to make informed enough opinions about it. I have used ArchiCAD for over 8 years, and never once have I ever had to script a single object in GDL, - and in that that also, I have modeled some of the most unusual geometry and objects, with the tools available.
I've been working with Revit during 4-5 months (since ~January/2007), and I can do things (see example attached) that with ArchiCAD I couldn't dream of. I’ve more experience (learning time) with AC ...
You have used ArchiCAD for over 8 years ... You can do it with AC?
2007-05-02 06:08 PM
refs wrote:I feel like I could almost do a search/replace with "Archicad" for everywhere you wrote "Revit"
My experience with both:
I have skipped ArchiCAD (and ADT) learned and choose REVIT because of one very important reason: simplicity!
In fact, since 1999, I worked around GIS technology, Bentley parametric technology (Microstation Triforma) and none of them corresponded my expectations. Just Revit!
REVIT principles seat on a well defined strategy which are well apprehended by the user once they start to use the program.
The elements are well structuralized in the following aspects:
- Model Elements;
- View Elements;
- Annotation Elements
Almost all of these elements are represented by "families", easily editable by any user with 3-4 months experience, like me, in contrast with GDL (ArchiCAD) users.
With REVIT, this organization is reflected in their "User Interface" which is quite simple.
I think with ArchiCAD these features aren't clear. Well, at least, I didn't understand them, and their interface it's not straight forward as it has too many icons and options.
The virtue is not in the user but in the program, believe it.That's just sad. I would rather 10 good people on a pathetic program than 100 bad ones on the best program on earth.
Another aspect, eventually the most important one: “Parametric Objects”.Now that one I'll give you. I'm pretty good at GDL and I still wish it were easier to make something parametric of your own.
With REVIT this is extremely easy with “families”; if I can do it … then everybody can😉
2007-05-02 06:31 PM
2007-05-02 08:20 PM
metanoia wrote:Dang, I was hoping we finally were setting the ground rules for Wes on Revit v. __ on AC for that online comparison...
I always hate it when Reviteers come over and pooh-pooh ArchiCAD -- "ArchiCAD can't do this, GDL sucks,myCAD is better than yours" etc. We've got better things to do than hide under bridges and ask people what the terminal velocity of a falling sparrow is...
2007-05-02 08:21 PM
refs wrote:Bricklyne wrote:This issue is dedicate to you.
2007-05-02 10:59 PM
2007-05-03 01:45 AM
2007-05-03 02:02 AM
~/archiben wrote:refs wrote:maybe you should consider using something like 3DS if you are designing themeparks?
... more example
~/archiben
2007-05-03 02:21 AM
Miki wrote:--> Revit nested families
Imagine that you have a door that can have several door panel, handle, mulions, trims styles etc. within one object. It is using external objects that represents those styles and connects them together. You don't see those objects in regular library, because they are macros. But when you change the door width the panel, trins, handels etc. adjust automaticaly. And this is very simple sample.
2007-05-03 02:57 AM
refs wrote:i guess you missed the heavy sarcasm. doesn't come across at all well in plain text and there's no emoticon.
Thank you for your 3DS tip, but our objective is to model projects with BIM tool. We have internal 3DS dept ... This works It's not for "renderings".
refs wrote:my emphasis. the enraging of the archicad audience was nothing to with revit. it was your clear lack of understanding of archicad combined with your saleman-like, annoying demeanour.
All with a "spear pointed to the head" of a simple anonymous BIM beginner that dared to choose Revit over ArchiCAD.
I never thought the opinions and ideas of a beginner, with 3-4 months Revit experience, would enrage such a huge crowd of ArchiCAD fans
