2007-01-22 08:52 PM
2007-05-19 08:20 PM
2007-05-19 08:27 PM
2007-05-19 08:50 PM
2007-05-20 01:36 AM
2007-05-21 01:51 AM
2007-05-21 01:53 AM
2007-05-21 02:27 AM
2007-05-21 04:13 AM
2007-05-21 06:32 AM
refs wrote:Maybe you think you made the correct decisions, but you need to prove it to yourself somehow? As for me, I believe the two programs are about equal at this point in time. On top of Laura's list, I've made my decision based on many other factors, probably more "chemistry" kind of things, such as my view of the respective corporate images, and what they stand for, to the way the building looks and feels in 3d view (the thick marquee thing was very sexy for me).
...I think I'm making the correct decisions, if that bothers you so much … please carry forward, read another post….
2007-05-21 04:38 PM
Miki wrote:Having used IFC export/import in Revit purely on an experimental basis -- I haven't really needed it yet, though the time is coming! -- IFC works in Revit just fine. I've heard stories of people trying to move projects from AC to Revit and vice-versa and not having 100% success tho. Is that what you're talking about?
Interoperability? Revit compatible with Revit Structures and Revit MEP. Nice. What about Tekla, SDS/2, and bunch of other formats? IFC in Revit just <b>[censored]</b>.
No support for slanted or profile walls, or non square openings. Compatibility with Autocad very limited (no layers support). Importing block as families? No? So sad. Revit Structures or MEP? Who is using it? It's like ABS for ADT. Mostly worthless. And by the way you forgot about Constructor with its MEP systems.Profile walls are right in the default wall properties dialog box
GDL vs Families? Are you talking about Ease of creation on simple objects, or features? Ooo you are probably referring to this simple parametrical objects, but at the same time you are forgetting that AC users have most of needed parametric objects already in standard library, and they don't need to create parametric objects (can but don't need) and creation of not parametrical Objects is as simple.While AC ships with a greater variety of objects (more's the pity for Revit users!) I still suspect Revit users are happier with the somewhat easier method of creating parametric objects in Revit. AC and Revit both allow creation of non-parametric objects more readily than parametric ones -- parametric object creation can be challenging but rewarding!
BIM A to Z. Hmm in your opinion of course. Can you define TRUE BIM? In my eyes AC is as true BIM as Revit. But more important is how from model you create set of Documents. This is where true BIM shows its face. Both software are equally good here.Revit used to have the upper hand here with annotation management features that seem to be appearing more in AC with v11. Glad to see this happening. Now that AC has virtual trace (a very good feature for coordination) the scales may have tipped in AC's favour on this point. I have yet to see how this works.
Add-ons. Say what? I need some external addons? How is that that during my over 10 years practice with AC (from small interiors to couple hundred mil $ hospitals) I never used one? Interesting. I mean I was testing some of them, even found some of the useful, but somehow never incorporated one... Do you have some good addons for Revit?Can you model terrain out of the box in AC? What does Architerra do anyway? Revit add-ons are for costing purposes mostly -- nothing for modeling or documentation yet, though I suppose it could be done.
Export from Revit to dwg better than from ADT? How? ADT's native file format is dwg? This area in Revit actually really <b>[censored]</b>. No layer make Revit not compatible with National Standard.Revit used to be more compatible with AutoCAD than ADT -- no joke! ADT exports used to require object enablers and the proxy objects would often drive vanilla AutoCAD users crazy. AutoCAD has these enablers built in now so there are no problems at present. Revit still creates the best DWG exports in terms of them being simple, vanilla CAD drawings for consultants. ADT users still create a lot of AutoCAD junk data that the consultants then have to deal with (details drawn all over the place in model space, etc.)
Learning time better for Revit? Not in my experience. Somehow my guys adopt easier to Constructor (workflow exactly the same as AC). After creating a wall an dimension comes time with reflections how to a sheet out of it, and here AC just flies.Individual users will learn the software that the resident expert knows best. Were you and I to train the same group of people on the two platforms, we would need THEM to truly make this statement verifiable. On layers: Revit has them -- they're called categories. Walls, doors, dimensions, text -- they all live on their own category that can be turned on/off. Custom categories can be added. CAD standards can be followed to the letter.
Migration to Revit from any package is a nightmare. The way of work differs from anything else. Lack of layers make things even worst. To much of software intervention of what you do. No way to transfer standards.
I think both systems are quite good with edge still strong on AC side. Teamwork, working hotlinks etc.I give Revit the edge on completeness of the BIM platform and ease of use. I give AC the edge on file linking, modelling via Maxonform, and rendering.
