ArchiCad 8.1 New Features
We all hear of the new improvements made in 8.1 and some of you know about it.
Since the product is already out in some locations, could we ask Graphisoft to release a PDF summary of the new features.
A document similar to the "doors and windows" improvements would be great to get us to speed while we wait.
Conrado
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
21 Replies 21
Aussie John
rengarch wrote:
I am on the Mac version of 8.1
Has anyone experienced the 'x','y','r' etc. single keystrokes not working?
OS x 10..2.6
Rita, I havent noticed it happening since upgrading to 10.3. ( mind you that has caused some other problems)
Cheers John
[/size]
__archiben
OS x 10..2.6
i've never had any trouble with 'x', 'y', 'r' keystrokes not working: archiCAD 8.0.x with 10.2.x and archiCAD 8.1 with 10.2.x or 10.3.x.
john - could i ask what kind of "other problems" you are having with 10.3, so i can be on the lookout? thanks.
~/archiben
b e n _ f r o s t
Aussie John
~/archiben
Ben
After updating to OSX10.3 I noticed that " save selection as a module"
doesn't have any checkboxes visible to "apply offset and rotations" ( which
when you click it remembered the name of the resaved module) and another check box (which I cant remember what it was called)
I had just started using modules and not having that feature now makes it
harder to use.
Selecting text-the highlight disappears after the initial selection
I'm still on V8.0r3
Does 8.1 have these issues?
Cheers John
[/size]
__archiben
Aussie wrote:
I'm still on V8.0r3
john
no problems with 'apply offset and rotation', or the other box, 'change hotlink to the saved file'. were you trying to save it to a place that you didn't have write permission?
no problems either with selecting text - sounds like it could be an openGL graphics card thing? are you using openGL for 2D redraws? my origin 'hotspot' disappears occasionally although it still registers as 0,0 when i hover over it - again an openGL thing i think . . .
~/archiben
b e n _ f r o s t
Djordje
Aussie wrote:
I'm still on V8.0r3
John,
This all sounds to me like a video driver/OpenGL implementation problem. Try to find a newer driver/disable OpenGL and check.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
JCovarrubias wrote:
I'm not in front of my Mac at the moment to test this workaround, but try :
ftp://techsupport:[email protected]
(public read-access to tech support FTP folders)
go to the "gs kb" folder and search for appropriate folders (662 and 663)
Same thing happens. I can get to the folders but as soon as I click on the documents themselves they disappear.
JCovarrubias
try the Internet Explorer browser instead ..
additionally 8.1 doc's will be posted on http://tr.graphisoftus.com
specifically:
- Installation instructions [8.1 Install - 2 pages.pdf]
- New Features [archicad v8.1 newfeatures.pdf]
- Feature Changes [81_feature_changes.pdf]
- Library update [New_Storefront_Windows_Doors.pdf]
- Fixed bugs [81r1_fixed_bugs.pdf]
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
That worked It would be cool if it worked with Safari and the Finder though.
specifically:
PDF's are now available
Just as a warning. It seems as though these PDFs don't open correctly in the Preview application on the Mac. I had to open them using Acrobat.
