Archicad 10 - Window Sill Problem
I've tried to align the sill with the vertical closure (like shown in the attached image), but I didn't manage to do that. Could you help me?
Thank you.
3 Replies 3
try overhang parameters in window setting
I've already tried that ... it seems that the sill continues to mantain that distance from the vertical closure, no matter what values I assign to overhang parameters. Maybe it's a bug.
Thank you for the suggestion.
I just did it in my project and I adjusted the sill over hang through the Parameters then brick molding, sill and... then toward the bottom (sill overhang side) I had mine at 2" and it was overhanging and changed it to 0" and it changed.
