2006-09-01 04:07 PM
2006-09-04 08:46 AM
Aussie wrote:John,
I would of though any crashing bug reported to GS would be at the top of the priority list to be fixed.
2006-09-04 09:29 AM
gkmethy wrote:Thanks
John,
We will check this, but please also make sure you report this bug to your local tech support.
And please always submit your bug reports! Each Hotfix contains the fixes for themost frequentcrashes. So the more a type of crash is submitted, the better the chances are for a fix. Crashes are not always listed in the "Fixed bug list" , since most of them don't have a comprehensible description. Nevertheless, each hotfix contains several of them.
2006-09-05 01:50 PM
Some more testing:
Even though you cant see them - add an object label to an object in section. Save as a quick view and add to a layout. It will crash Archicad when updating.
2006-09-05 04:17 PM
Rob wrote:Yes you probably heard my screams from Adelaide. Also sometimes it turns off when you change the ID as well. Apart from the quirks I like labels
one more thing with the label tool - it tends to uncheck the 'label elements' check box after moving/changing label type or ID of an element AND at the same time keeps the label on, so to get that fixed we have to click on the check box (label disappears - the check box is ON) and then click that off and back on again. I can hear screaming of our drafties - 'where is me bloody label' in my dreams already.
2006-09-06 01:41 AM
2006-09-06 01:45 AM
~/archiben wrote:Not sure if you're taking the mickey out of the kiwi accent, or swearing without being censored, but I laughed anyway.
hotfux....
~/archiben
2006-09-06 01:55 AM
s2art wrote:take the mucky? me?
2006-09-06 03:36 AM
~/archiben wrote:And all this time I thought you were just a disgruntled Aussie. ':D's2art wrote:take the mucky? me?
the later - originally - but i dud notice the kiwi in me coming out too . . .
~/archiben
2006-09-06 05:10 AM
~/archiben wrote:So it is pits instead of pets, huh ?
2006-09-06 06:11 AM
Rod wrote:nah - far better than that!
Djordje wrote:it's already the pits . . . therefore it would be "the putts" . . .
