2006-04-26 01:54 PM
2006-05-03 08:36 AM
Rick wrote:Rick,Aussie wrote:I use lbks for quick reference extensively (I do stock plans and have many, and many phone questions), and I will miss that...
I'm of mixed feeling of the plotmaker/Archicad merge as I often use Plotmaker for quick reference to the drawing set...
2006-05-03 10:19 AM
2006-05-03 10:43 AM
2006-05-03 01:36 PM
2006-05-03 03:04 PM
Petros wrote:So that will be a new feature on AC 11.
The ability to create profiles on curved walls was there from 2003.
Now we are in 2006, AC introduces profiles but only for straight walls.... I still cannot understand why.
Petros
2006-05-03 03:56 PM
Erika wrote:Erika, that's something I actually never considered, but I always work on small projects. Even with a large one, that seems to be contradictory to the philosophy of improving the workflow and incorporating plotmaker into one file. It is easy to publish to pdf's in 10, so I would do that for quick reference if needed, but I doubt I will just because I want to know I am viewing the latest version, and I have so many active files. You can not save out as a PMK, which is a big issue IMHO in AC10. However, it is what it is (GS's opinion) for now, but I hope it will change in an update which will help with legacy files. Old projects can be migrated, but that requires time, and I have 100's. Slowly I will do so, but not with the additional 100's that are custom modifications, so PMK's would be good. keeping 2 pln files in 10 would still involve linking views, and maybe with a large file it prevents bogging down, but I don't know as I don't have large file. Without a saved pmk's the pln/book links to, the pln/book would still need to have a live update to display, which seems to be the same thing to me as one file??? Maybe with a huge file it chokes?
Rick,
In 10 they outline 2 ways to set up the layout book. One combines everything, archicad + plotmaker, into one file. The other allows us to continue to keep the layout book as a separate file, this time a separate pln file [rather than an lbk]. This second method was mentioned as useful for large projects.
I was wondering why since you, John and many more of us have found it convenient to use plotmaker as a quick reference you decided not to keep it as a separate file. New to 10, I am hoping you will discuss your rationale, pros and cons etc.
Thanks
2006-05-03 05:06 PM
Erika wrote:One word: SPEED.
Rick,
2006-05-03 05:37 PM
2006-05-03 05:42 PM
Erika wrote:I do not pretend to understand the GS design intention...
Rick & Tom,
Thanks for your replies. I am glad to hear the combined file is working to everyones expectations.
It is curious then that in the new features guide under migrating 9 projects to 10 they have the 2-file option and mention it for large projects.
How is the combined file working in Teamwork?Pretty much the same. You just have a new tab for "Layouts".
2006-05-03 05:54 PM
