Archicad 10 vs Archicad 9 managing polygons
Hi. I have some feeling about how Archicad 10 manage countours with the magic wand. It feels to me that it worked better in Archicad 9. I'm trying to make a fill to an urbanism drawing, and most of time it can't recognize areas. But Archicad 9 does it.
I've tried some interesting things. I've used polyline and simple lines to define the area and it goes wrong in both cases.... but if you reduce the extension of the area to recognize as a closed polygon then it works better....
Really disapointing
Djordje
Ace
Really disapointing
Can you post a screen shot?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Yes. The first image is the startup situation..... I have a huge are archicad is not able to recognize
The second image shows what I have to do... I need to split the area which magic wand is applied to, so it recognizes the polygon..... But Archicad 9 is able to recognize the whole polygon...
