Archicad 11: reduce the number of nodes in a polyline
It's possible to reduce the number of nodes in a polyline?
7 REPLIES 7
hello,
Yes
With good parameters in the magic hand box setting
Masse wrote:
hello,
Yes
Where can I find "magic hand box setting"?
schagemann
options > magic wand settings > segments along arch
macinteract
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
Let me give an example to explain better
In my drawing there is a line with many points. I'd like to reduce them.
In this case, how the magic wand tool works?
If I click on the magic wand, nothing happens
I tried to change options in magic wand settings but this attempt was in vain
schagemann
should have read your original entry more closely...
the magic wand (spacebar) only comes into play if you wish to 'trace' a closed area.
for your purpose simply do the following:
1. select the polyline;
2. right click and click on 'select & activate tool';
3. click on a node point you wish to remove and drag it over another node point to remove;
macinteract
I thought there was a specific command
Ok thank you very much
The magic wand will also trace an open contour if you click the edge.
