‎2010-11-06 09:38 AM
‎2010-11-06 09:58 AM
‎2010-11-06 06:39 PM
Masse wrote:Where can I find "magic hand box setting"?
hello,
Yes
With good parameters in the magic hand box setting
‎2010-11-06 08:36 PM
‎2010-11-07 10:26 AM
‎2010-11-07 10:42 AM
‎2010-11-07 02:45 PM
schagemann wrote:I thought there was a specific command
should have read your original entry more closely...
the magic wand (spacebar) only comes into play if you wish to 'trace' a closed area.
for your purpose simply do the following:
1. select the polyline;
2. right click and click on 'select & activate tool';
3. click on a node point you wish to remove and drag it over another node point to remove;
‎2010-11-09 03:29 AM
schagemann wrote:The magic wand will also trace an open contour if you click the edge.
