Archicad 11 to EPS
Hi ... I´m trying to convert the drawings to EPS to work with adobe illustrator but I don´t know how to convert it. Anybody can tell me how to do this ?!? Is there any patch that i can download ???
Thank you
4 REPLIES 4
TomWaltz
Graphisoft removed the ability to make EPS files in Archicad 10. I don't know of any way to make them in 10 or 11. I tend to use PDFs
Tom Waltz
Rafal SLEK
PDF format is better now than eps export. In AC11 pdf is improved - you could also Save as with additional features (eg. better resolution for curves)
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
Thomas Holm
Illustrator opens PDFs directly. If you need it later, you can save EPS from Illustrator.
I've done that with Archicad 10... I opened the pdf files in the illustrator and they were ok. but when i started printing the lines disapeared!!! Is that convertion really improved ?!?
Thanks for the replies!!
