Archicad 17: Wall connections disappear and appear again!
I get this recently. Wall connections are turned on, its not that. The walls connect. The connections appear and then disappear and so on. The dimensioning gets crazy.
Anyone had this problem and know the fix?
This is a serious issue, and I hope it will get fixed soon! I cannot work!
1 REPLY 1
My guess is it is your 'Partial Structure Display' settings changing.
These are saved with the views so can be different for each one.
These will affect the dimension because the dimensions are specific for each PSD - i.e. they only show on the PSD that was active when the dimension was placed.
Or it could possibly be the Renovation Filters.
These too are saved with each view so as you change views in the View Map you may be invoking different settings.
