Project data & BIM
Archicad 19 Attribute Manager Missing
Trying to start a new project and in the setup, discovered my attribute manager is missing. I have looked at the Project Preferences/Work Environment, but I cannot find it to add it back to my Options Menu. Am I missing something here? I have updated to 4011, maybe something to do with that? Any help/suggestions/ideas appreciated.
11 REPLIES 11
Steve Jepson
Try the All commands in alphabetical order tab. ? Not there either?
Steve,
That's the first place I looked. Its just not there....I'm really puzzled here..
Steve Jepson
re-install
Try loading a default Work Environment and see if it is there.
Not sure why it is not in the all commands.
Barry,
I reloaded with default's and still not there. Guess I will just have to do a reinstall. Don't want to, but at this point, see no other choice.
Go to the Options\Add-On Manager Dialog and check whether the Attribute Manager Add-ON is enabled. If not, then check its checkbox to enable it.
Then reapply the Standard Work Environment for its menu command to appear on the menu.
I did that. It says "The file is an outdated Add -On that cannot be used with this Archicad version. Any one have the Attribute Manager.apx file for 19 I can "borrow" to replace the one I have? Maybe that will solve the problem. I hate to do a reinstall to fix just one file.
Erika Epstein
I'd do the reinstall, who knows what else is missed up...
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
That's probably true. Is it better to uninstall first then reinstall, or would it make that much difference?
