Archicad 21 stair function not working well---please help
hi I just started to use Archicad 21, and I like the stair function it provides. The stair I draw shows nicely in 3D. However, the same stair does not show up correctly in 2d floor plan. I am attaching the image of the 2d stair I drew here. Can somebody tell me what is wrong with the stair I drew and how can I fix it? Many thanks!
4 Replies 4
Bruce
That is the default line type used by the tool. Mine defaults to the cloud line type. You need to go through all your plan settings and change the line types to what you need. Be aware that some tabs have multiple pages.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
David Maudlin
seutaojiang:
If you can use one Type for all lines, then go to Stair Settings > Floor Plan Display > Floor Plan Symbol Overrides > Override Object's Line Types.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
hi David and Bruce, Thank you very much for helping me! I think your answers fixed the problem!!!
David Maudlin
seutaojiang:
I'm glad that helped, thanks for adding your signature.
