vfrontiers
Archicad 25 Binary Object
Sorry... Old dog Duane can't figure this newfangled forum out... was very straight forward before...
Anyway, I have no idea how to post this in an appropriate topic, so ....
Is it possible to save BINARY objects anymore?  I have several lots where I've done house on in the same neighborhood.  I am starting another and want to see the others as context.
I have no intention of using modules as it will be a layer / attribute nightmare... so I just wanted to save the built ones as objects... Which I can do just fine...
But, knowing there will be material issues, I was hoping to save them as BINARY but no longer see that option...
Let me know of any way to achieve this...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
3 Replies 3
Podolsky
Ace
You can do that. First save your object - Archicad by default placing all object to Embedded library. After open the new object in library part editor (File/Libraries and Objects/Open Object...) and use Save As command. When you navigate to save the object to the disk (let say to the Desktop), Archicad will show you an option to save it in binary format.
runxel
This option is indeed no longer available. Got killed in 25.
vfrontiers
well that figures!
Duane
Visual Frontiers
AC3.14 - AC29
