2022-09-15 07:46 PM
Hello, recently we faced a problem after installing Archicad 26 int.
The case is:
In 2d window if we enable trace reference and pick up a Wall Tool with ( Alt+C), when start drawing a wall, there is heavy lag , which makes impossible to finish the desired wall. Meanwhile the drop menu for the wall parameter-building materials is blinking in unusual way.
Any suggestions way is this happening and how to resolve this?
Thanks in advance.
We`ve got several licenses and this bug is in all versions of A26INT, including the 4004 int.
All videocards are quadro`s like p4000, p5000 , and one RTX3060 12gb. same thing everywhere.
2023-01-30 01:25 PM
Same problem here, A26INT, update 4019. Also happens only when I activate trace reference. And it happens only with basic walls, when selected. Composite walls behave normal.
Videocard NVIDIA GeForce RTX 2060 SUPER.
2023-08-16 10:51 PM
Same problem here. Archicad 26
2023-08-17 03:20 AM
I have not noticed any issues, but that is not to say that there isn't.
What are you using as your trace reference?
Is it a view point from the Project Map, a view from the View Map or a layout?
