Archicad 26 - Line types not changing
lfm1791
Hi All,
I am working on customizing my template file, adding my layers, pen sets, View Settings, etc... As I work through that, I realized that I am not able to switch from one line type to the other. It is stock on "Solid" as the line type. Any recommendations?
Luis
Archicad 26
MacOs Ventura 13
MacBook Pro M1 Max 32GB RAM
Lee Hankins
This is a known bug in Ventura. Use the arrow keys to move up and down the list.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
Thank you Lee. Much appreciated.
Also, see the other Ventura issues here.   This article will be edited as more issues are found, or as updates to fix issues are released.
https://community.graphisoft.com/t5/Setup-License-articles/macOS-13-Ventura/ta-p/359447
(at present the 2nd and 3rd sentences do not reflect the issues shown later in the article.8
