2007-06-18
03:48 PM
2023-05-25
04:59 PM
Rubia Torres
2007-06-18 08:03 PM
2007-06-18 08:21 PM
2007-06-18 09:02 PM
nats wrote:Well, attitude and aptitude is (nearly) everything. I've scanned your posts since last July, where you note that you used AutoCAD for 10 years prior to ArchiCAD.
Its not my fault I work in an office that is using Archicad and should by all rights be using Autocad. Yes you are right I banged on about this for ages when Archicad v10 came out and I guess the new release has done nothing to satisfy my problems with the software.
I have tried using 3d but just dont get anything worthwhile out of it elevations are rubbish, sections are nonsense, plan walls dont connect right and stairs/roofs are a nightmare.
nats wrote:This is now 12 months of working in 2D rather than modeling. With any reasonable training, you would be producing live sections, ready to plot, the first week of usage. Once learned, you produce live sections faster than you can possibly produce them in 2D...and you eliminate issues of errors/omissions and much more, decreasing your employer's liability and increasing your productivity.
We work this way all of the time at the moment - just drawing walls and adding doors and windows and then drawing completely separate sections and elevs on different 'storeys'. Archicad works pretty much like AEC AutoCAD in this respect. Although Archicad v10 doesnt easily allow for this kind of flexibility (Archicad v9 was better is this respect) but it can be done if you think of storeys in the model just as you would do different drawings in AutoCAD. Its something Archicad need to address if they want to retain architects like us who have no intention of drawing in 3d.
I am still trying hard to learn ArchiCAD 3d modelling after 4 months of working with it and am still not even able to get a section generated out of the model nor an elevation that will look anywhere near accurate or even remotely sensible! I have heard others here say they can do it but for me its far quicker to draw in 2d when you 'need stuff out' rather than poncing about with a 3d model.
2007-06-19 12:13 AM
2007-06-19 01:43 AM
TomWaltz wrote:If you look at the multiply command available right from the pet pallette (works on lines) you'll find that it does even better than autocad offset if you want more than just one copy of something - choose the offset, or the total distance to be evenly divided or other options.nats wrote:Yes, it is available. Try looking for "offset" in your user manual PDF. MAN, are you insistent on not learning! You can offset ANYTHING, walls, lines, fills... anything that is linear or polygonal in nature. The sequence is a little different from Autocad, but it works really well. It's not just the "offset" button on the Pet Palette. It's also a button on the Control Palette and the Standard Toolbar. Try learning something. You might like it,
Offset by the way is not available - only for polylines, not normal lines, so its pretty much another useless feature ie I have yet to find a reason for it. Offsetting single lines on the other hand (ie as in Autocad) would be immensely useful as it frees you from having to use a skewed grid all the time or endlessly dragging copies etc.
2007-06-19 02:30 AM
nats wrote:Welcome to the profession, although i think you have been at it for a while now. I think you will find most of the guys on here are also architects - they just happen to know how to use a particular tool of their profession. You know AutoCAD (2D). We know ArchiCAD (3D).
Hello, Im an architect here, I do drawings and design buildings, I dont know 3d modelling, and if I had the time I would learn 3d Autocad & 3dmax or alternatively Sketchup for quick renders - but definitely not Archicad!! When will this sink in??
nats wrote:Well as you know i would strongly disagree with you on this - and so does Autodesk actually, why else do you think they bought Revit?.
I would very much like to hear how you would manage to do these things as I disagree with you really - they are not available unless you are willing to learn programming and we are not (we are simple architects not IT specialists, just getting a PDF drawing plotted is often at the limit of our knowledge).
I just dont think 3d is the way to go and I know Ive said this before. I think (and so do others here) that 3d in architectural cad is just a 'fad' that will last a few years. It just doesnt work where you have architects who cannot programme rather than it specialists. Perahps for very large firms or single practitioners it may work but for most firms I see 3d being completely irrelevant.
Peter wrote:In fact you will think it is a bit like using a chisel and stone tablet when there is a whiteboard and marker in the room.
Trust me, once you 'get' ArchiCAD ... You will not believe that you thought that pushing 2d lines around was the best way to describe a three-dimensional structure.
2007-06-19 12:19 PM
2007-06-19 02:12 PM
nats wrote:I might be going out on a limb here, but you will probably find that direct questions (like "How do I get ______ to do what I need?" or "How do I set up ______ to get ________ result?") will get better results than blanket complaints about something not working.
I suppose this is what I was hoping to get from all you experts here - either where to go to learn all this stuff properly, or confirmation that r11 corrects all the lousy parts of v10 regarding connections, stairs, generated drawings etc (but this doesnt sound the case from other posts here).
2007-06-19 04:59 PM
Well I am aware it is like I am preaching a false religion to a devout follower here. And what should I expect as most people like myself wouldnt even know this board exists never mind how to post on it!This board exists and works exceptionally well because a few earnest adepts respond to earnest, well phrased questions. A community has developed out of this spirit of dialogue between the neophyte and the truly professional.
Although having said that I am quite an advanced computer user myself. I even play computer games etc in my free time. Ive been involved in computers since the ZX81 and CAD since Autocad R12The last time ArchiCAD shipped in a tin was back in the early nineties. It was called ArchiCAD 4.55. I would deduce from your particular turn of phrase(s) that 2D CAD in the form of AutoCAD 12 has probably not advanced beyond your needs and that you might be better off with a copy of that running on DOS.
including Microstation - so theres nothing about computers that scares me. Even 3d cad doesnt 'scare me' it just doesnt seem to work IMO.
I admit I am perhaps a little stuck in my ways being quite good at 2d drafting. But my main problem is Archicad just doesnt inspire me to want to get into 3d. Perhaps another 3d program would be better but unfortunately I am stuck with it in a wholly 2d drafting environment (I dont know why other than a boss thought it was a good idea at the time) and there is no likely chance this will ever change with my present firm.Get you and your boss to the the Orcutt/Winslow web cast straight away. Understand that you are part of an organization and that while you might have different perspectives on the enterprise you both have to have a full-time commitment to it. Here is the link: http://www.graphisoftus.com/owp_event.html
The main problem with it to me seems to be that the generated drawings in my opinion, from the limited knowledge I have, are just pretty useless without a load of 2d drafting over them which makes them kind of pointless doesnt it? I look at a building with projecting terracotta rainscreen cladding etc and for the life of me cant even begin to understand how I would ever do that in ArchiCAD 3d.Go and build something - something you can put together in your back plot over a weekend and look at the problem again after. Stop drawing. Pick up a hammer and a saw, use them for a few days and then have go with ArchiCAD again.
There are two of us here who have actually tried doing 3d models at home and gave up pretty quickly. We just found them enormously slow to create and the resulting visuals and sections rubbish. Plus it seems without add-ons with vanilla Archicad is impossible to get a decent design out of it that looks anywhere near convincing unless you are doing a 'brick box'.Twice I have had the great good fortune to meet people who built masonry walls in ArchiCAD, brick by brick. The first was an utter twit and was sacked from his job when his employers found out about it. He went on to make films, rather good ones.
And the fact there are no books or walkthroughs on how to do a typical complex design doesnt help at all either. Its almost as if Graphsoft are not bothered who takes on the software or not. I would have thought with such a complex piece of software there would be a decent easy to read book on it at the very least. Ive seen all the various online tutorials showing new features etc etc and they are all pretty useless in that they dont relate to an actual sensible architectural project. Even the one that shows how to build a building in several steps shows sections that are unrealistically simplistic and constructions that are just plainly unrealistic. I would love to see a tutorial or walkthrough showing how to construct a steel framed building with rainscreen cladding and concrete beam and block floors for instance!-------------------! SHHHHH! Shut Up and listen to those you have asked for help. Respect them and learn from them. Shut Up and Think for Yourself.
I suppose this is what I was hoping to get from all you experts here - either where to go to learn all this stuff properly, or confirmation that r11 corrects all the lousy parts of v10 regarding connections, stairs, generated drawings etc (but this doesnt sound the case from other posts here).When you can snatch the pebble that is 4.55, you might be ready to tackle v11.
So other than the typical responses I seem to get like 'Archicad is great because....' how does one manage to actually get decent drawings done in this software? And why cant they seem to get away from walls and slabs that obviously dont work, it seems to me, and start using simple blocks that can be rotated and moved around freely etc and interchanged. And when will they start producing libraries that actually contain things you need like realistic balustrades, handrails that actually connect. And when will they have slabs with screeds that actually work correctly in section with wall junctions?----------------------! perhaps you might rent the Monty Python DVD containing the Eric Idle sketch about Anne Elk and her theory on dinosaurs.
Because as far as I can see none of these work properly and if I cant draw simple things like wall junctions properly without 'workarounds' why would I want to even try to get further into the software? Its just all a bit crazy to me!!BUT SIR, YOU DON'T SEE. ANYTHING. SEEK PROFESSIONAL HELP IN THE FORM OF A REAL PERSON VISITING YOU AT YOUR OFFICE LOOKING AT YOUR PROJECTS. THERE IS NO SUBSTITUTE FOR THE ONE ON ONE CONVERSATION BETWEEN TWO PEOPLE BECAUSE AT SOME POINT YOU HAVE TO STOP TALKING AND LISTEN TO WHAT THEY HAVE TO SAY, TOO!.
2007-06-19 06:33 PM
