2023-09-15 08:59 AM
Hello Community, I am facing an error in the Info box Palette: The icons for options are missing for selection types like polygonal, rectangular or rotated rectangle this is happening specifically when simple selection is to be done and not in the marquee as the marquee shows the options properly. Just when in the arrow command u want to select, icons and those options become blank... Please help me with the same
A screenshot from the project is attached...
Archicad 24
Solved! Go to Solution.
2023-09-18 06:40 AM
Nothing worked but then right now to change the geometry methods for selection and for my convenience, I have set a shortcut which is working fine! I guess there is some unfortunate glitch which my Archicad has faced. Nevertheless, thanks to all community members for the support and help!
2023-09-15 09:09 AM
Does it happen when you open a new instance of AC? Have you tried restarting your computer?
2023-09-15 09:20 AM
Yea it has been an issue since I installed Archicad, regardless of new instance or even new project file, restarting computer , etc. Issue still persists
2023-09-15 09:25 AM
Have you tried running the installer again and doing a repair?
2023-09-15 09:27 AM
Yup, have gone through that too Its just having this issue ... The thing unable to understand for me is that the same options come with marquee where they are visible but not with arrow selection
2023-09-15 09:33 AM
They are different icons, and different options compared to the Marquee Tool... You wouldn't happen to have screen scaling on?
2023-09-15 09:41 AM
Can you explain what exactly that is and how to do that?
2023-09-15 09:43 AM
If you are on Windows:
2023-09-15 09:52 AM
Still the same issue persist not resolved Even closed restarted all again to apply scale to all Still same
2023-09-15 10:09 AM - edited 2023-09-15 10:10 AM
Do you have any special window personalization setting (background, theme, colour...etc)?
Can you run Archicad and test in diagnostic boot mode?
