‎2004-07-17 09:01 PM
‎2006-11-17 05:24 PM
Haneef wrote:Do I read that right, that you think Graphisoft should start programming Linux and writing parts of Linux so it could Archicad, and if they cannot start volunteering effort to this cause, then they cannot handle other challenges?Haven't read all the post, but here's my few cents:
1) The advantage of developing ArchiCad for an open source software such as Linux is that Graphisoft could contribute to and shape Linux to run ArchiCad to its best. (If Graphisoft can't do it, then I'll be worried about how they'll innovate and cope with other challenges)
2) The only thing preventing me from switching to Linux is that ArchiCad is not available on it.
‎2006-11-18 03:11 PM
TomWaltz wrote:A bit of strong words there. If one looks at the topic in question, it does not really matter whether my words have been misinterpretted or not.
...Do I read that right, that you think Graphisoft should start programming Linux .......they cannot handle other challenges?.....
‎2006-11-18 06:38 PM
TomWaltz wrote:i was suspecting at first.... but now i realy wonder....Haneef wrote:Do I read that right, that you think Graphisoft should start programming Linux and writing parts of Linux so it could Archicad, and if they cannot start volunteering effort to this cause, then they cannot handle other challenges?Haven't read all the post, but here's my few cents:
‎2006-11-18 06:45 PM
Constantin wrote:Nope. I'd just rather see a highly functional next release of Archicad than a lame one accompanied by an announcement of a Linux version.
ARE YOU IN ANY FORM ASSOCIATED WITH THE COMMUNIST PARTY OR MICROSOFT??![]()
‎2006-12-12 10:23 AM
stefan wrote:there is an open-source-based version of java available (java-sun, i think) (dont know, if this might help solving the problem...?) and also an open-source "quicktime" (i think, its called "open-quicktime" ^^)
You might try installing it in Windows and copying the installed folder over. I remember that older ArchiCAD versions (e.g. 6.0 & 6.5) could run without installation, since all required dynamic link libraries (DLLs) are inside the main ArchiCAD folder.
I suspect problems with the hardware lock detection, though, since that needs Sentinel (6.x) or WIBU (8.x 9.x) software installed. You could try with a student version. I still have the student version of 7.0 which ran without lock (and with certain limitations).
The installer is Java-based, which is probably one of the main problems.
FWIW, BricsCAD Architecturals (based in IntelliCAD) is "ported" to Linux, but only through WINE.
‎2006-12-18 06:49 PM
‎2007-05-28 07:06 AM
‎2007-05-29 09:52 AM
‎2007-05-31 01:20 PM
‎2007-05-31 02:53 PM
syber wrote:Exactly. ArchiCAD is a vertical market product with a smaller potential client base and much more complex programming requirements.
...with far more wide range of usage than AC...
