Osmar78
Archicad freeze - move nodes
Hello everyone,
I have a few questions about drywall.
1-When I create a drywall wall I can't move the node to transform an opening into a window or a door, the archicad blocks  (it happens with the work I'm doing but if I create a new file I don't have that problem anymore). Send an image attached.
2-To create a wall from the brand pladur, I think you have to make a wall in archicad and then go to design extras and click on wall accessories. however the initial wall remains together with the drywall wall, am I doing something wrong?
Thank you.
Best regards.
Is this a 3rd party add-on or one created by your local distributor?
I have not seen this as standard with Archicad.
It may be best to contact the people that created it.
Osmar78
It´s a 3rd party add-on. I will ask the local distributor for some inputs.
Thank you.
