2011-08-04 10:29 PM
2011-08-10 09:38 PM
Peter wrote:How do you make the curves smooth?
Hello Steven,
Again, please see this thread. The method shown does work
and the curves in the complex profile are smooth.
http://archicad-talk.graphisoft.com/viewtopic.php?p=103276&highlight=raking+molding#103276
Peter Devlin
2011-08-10 09:49 PM
2011-08-10 10:37 PM
2011-08-10 10:58 PM
2011-08-10 11:26 PM
Steven wrote:This doesn't really work. You can only get away with it when the eaves are too high to see clearly and even then it still requires that the profiles are different heights or they won't even come close to matching. What you describe is not skilled carpentry but a well meaning hack job.
...not a true miter, requires a coping saw, and is very tricky
2011-08-10 11:31 PM
Steven wrote:This is true of the cyma, cove and some ovolos but there are also some that are elliptic. I don't recall seeing any classical or modern ones that use a spline curve.
I believe the classically correct crown molds are made from arcs/circles, not splines as some of the new stock ones are. Circles are nice and smooth!
2011-08-10 11:38 PM
2011-08-11 12:00 AM
2011-08-11 12:12 AM
Peter wrote:I don't think there is any significant difference between versions. ArchiCAD models are and have always been entirely polygonal. The smoothing occurs in the rendering algorithm so the details will always be somewhat faceted at the edges.
Hello Steve Jepson,
I thought you gave the solution to the smooth problem on this thread.
http://archicad-talk.graphisoft.com/viewtopic.php?t=37239
But maybe not. The complex profiles I made for the eave
and rake moldings were made in AC 10 with no problem.
So it maybe an AC 15 problem. I don't know because
I do not have AC 15.
Thanks,
Peter Devlin
2011-08-11 01:00 AM
