Arrow without Dragging
When using the arrow tool, it really has to start from a place where there are no objects. If there are objects there, like a zone, it tries to move that zone.
Is there any way to use the arrow tool, without it trying to move whatever is where you start to draw a selection?
4 REPLIES 4
Select your elements to move, CTRL-D (CMD-D for Mac) to invoke the Drag command, then pick your start point wherever you like.
sinceV6
Hi.
You might want to turn off Quick Selection (in the arrow tool info box, the magnet to the left of the arrow). You can also use the spacebar to alternate its state on the fly.
Best regards.
sinceV6 wrote:
Hi.
Best regards.
yeah, I think that's the problem;) Spacebar to the rescue. Thanks.
Just wanted to add my 2cents in too, just found that there is a button in the default settings (top menu bar) when you have the Label selected, there is a button next to where you can change the layer of the label you can toggle between two options.
1 - associative (linked to any object e.g zones, walls etc.)
2 - independent (not linked to any object e.g zones, walls etc.)
