Attribute Manager : Importing Materials
When importing (Overwriting) a Material using the attribute manger, the Materials texture Dimensions are not imported. Can others show this to be true.
I am overwriting a material in an existing plan using a material in a Template PLN file. The Dimensions of the associated texture are not being overwritten as I would like.
1 REPLY 1
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Hi Jay,
quite strange because from what I knew this was a known bug that should have been solved by the last 1965 update...
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
