2005-02-18
09:28 PM
2023-05-25
06:21 PM
Rubia Torres
2005-02-19 10:27 PM
constantine wrote:Make sure that you have the same fonts installed on your system as what is referenced in the autocad file. Even the shapes file. I have setup a seperate fonts folder with all autocad type fonts (other than truetype) for when I reference a dwg file.
I open an AutoCad file with my ArchiCad 8.1 and some text is becoming unredable (questionmarks).
Can somebody help me giving an advise on the procedure so to read the AutoCad text when opening the file in ArchiCad.
I appreciate your help
2005-02-20 06:17 PM
2005-02-22 06:30 PM
constantine wrote:Better idea is to tell them to do eTransmit. This will pack the DWG, all Xrefs, blocks, fonts, whatnot into a single ZIP file.
What I will do is to ask them to attach the fond as well. I assume that making a foldar with all autocad fonds they may possibly use is a good idea.
2005-02-22 09:22 PM
