Autocad Plug-in?
I have an archicad model that i would like to bring it into Autocad, is there any converter or a plug-in i can download by any chance?
4 REPLIES 4
Djordje
Oh yes!
It is invoked by pressing SaveAs while in the 3D window, and choosing DWG as the format.
The Translator needs to be set up.
Why do you want to do this? Just curious
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Jacques Toerien
Djordje,
But you won't get any notes of dims etc. You will only get the 3D model with no 2D info.
edit: Generally, I can't see this helping in the EDU circles as students often work on projects with other disciplines (engineering, survey etc)
-JT
2012 13" Macbook Pro 8GB Ram, OS X 10.14.6
2010 Mac Pro 2x 6 Core 2.93Ghz Xeon, 48Gb Ram, OS X 10.14.6, RX 580
To summarize the summary of the summary: people are a problem. - Douglas Adams
According to the manual, the Student version cannot save as DWG. However, the University version (lab version) can. So, if you are running the Student version, take your file into the lab and you can save there. AFAIK.
HTH,
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Djordje
If you want 2D, you save from 2D windows.
As Karl correctly pointed out, not from student version.
Djordje
HP Omen
