‎2007-02-08 06:53 PM
‎2007-02-08 08:59 PM
If you use the eyedropper/alt-click to load up the parameters of a wall the height of the wall is correctly set, but its bottom reference level / absolute base height is as follows:
the element absolute base height + the height of the current story above the original element's story
‎2007-02-09 02:55 PM
Joeri wrote:You are right, that is a frustration with them, in fact it was while I was struggling to resolve some of the missing bits of walls from the intersections above that I found the missing polygon wall bug and the alt+click eyedropper bug.
... it's strange to have disappearing lines of walls / corners / ... when there are faulty connections a few stories above...
