‎2003-10-31 07:47 PM
‎2003-10-31 07:48 PM
‎2003-11-01 04:03 AM
‎2003-11-01 09:49 AM
Thomas wrote:Going to Tips now; the message is quoted fully in order not to break the discussion.
I found out how to link directly to the MacOSX Hint in question!
http://www.macosxhints.com/article.php?story=20031027180428655
But for the lazy ones😉 Here's the text:
I was installing and testing my HP printer on Panther today and noticed that there are a few new options tucked away in the Print dialog (I mean besides the fax!). For one, the Colorsync pop-up panel brings up the ability to apply Quartz filters to print jobs. There are seven built in filters, as seen in the screenshot, plus the ability to create your own (Add Filters). Upon creating your own, the Color Sync utility fires up and gives you a bevy of options to filter your print jobs and integrate them into a PDF workflow.
Definitely one of the unsung features to be found in Panther.
[robg adds: The ColorSync Utility (which lives in Utilities) seems to be a very powerful little app, showing you the effect of the various filters as they're applied, along with a slew of other options. Even if (like me!) you're not a graphics wizard, it's worth checking out at least once.]
And here's the picture:
‎2003-11-01 06:17 PM
‎2004-07-20 08:39 PM
Thomas wrote:Does NOT work from AC7 under 10.3 to an HP Laserjet 8150 via PostScript.
Please note that this tip still needs confirmation from someone who has Panther.
Please test it in both Archicad 8.1, 7v3, Plotmaker, and with both non-postscript inkjets and large-format primters, as well as Postscript printers.
‎2004-07-21 02:11 PM
nathan wrote:Well, here the Colorsync filters in Panther work with all printers that use a standard postscript OSX printer driver (some variation of Laserwriter) and a printer-specific pdf file. Example: Our Xerox color laser. (expensive, but worth every penny - and I'm not bought by Xerox /yetThomas wrote:Does NOT work from AC7 under 10.3 to an HP Laserjet 8150 via PostScript.
‎2004-07-21 05:31 PM
Thomas wrote:you mean like this, (attached)?
It could be possible for some guru to create a ColorSync filter that did this. Until someone does, we'll have to live whith what we've got: Plotmaker's the only way to get all lines black on the Mac.
‎2004-07-22 03:47 AM
‎2004-07-29 03:23 PM
