BIMx Walk through
Can a BIMx walk-through be uploaded to our company web site?
3 Replies 3
I don't see a reason why it couldn't.
If you created it, it is your intellectual property, you can put it there if you want.
Or is there some aspect of the situation that makes it not so simple?
I have successfully attached the BIMx files as links that download to the users computer. Check it out here: http://www.vswc.com/eatonstadium
Thanks Brian,
That's exactly what I want to do. What I'm curious about is providing the viewer with a pre-programmed walk-through. I've had trouble programming a smooth, guided walk-through. Is this something that is feasible with the BIMx model?
